Removing spacers affect alignement?
Old Jun 24, 2010 | 10:03 PM
EK9MAX's Avatar
Default Removing spacers affect alignement?
I got some 3mm spacers on my car. I had teh alignemnt done with these spacers on.
I'm rubbing a bit, and I think it may be due to the spacers. If I remove teh spacers, will it affect my alignment? In other words.... will i have to get another alignment?
Old Jun 25, 2010 | 12:36 AM
SpitfireS's Avatar
Changing alignment = changing angles: camber, caster and toe.
Adding/removing spacers = changing track width.
Like using a wheel with a different offset (ET)
Option #1: Adding/removing spacers do not change alignment.
That said: adding/removing spacers could change the load on the springs and this could result in the car sitting slightly lower/higher.
IMO even when the car's not moving.
And that changes the alignment.
Option #2: Adding/removing spacers might change alignment.
GavinSSAP1
Feb 24, 2011 02:41 PM
boiii4
Nov 9, 2009 05:05 PM
s2kinfinite
May 3, 2007 03:01 PM
