manifold fitting
ive just fitted my buddy club one and its a real simple process,
jack the front drivers corner of the car up on a axle stand,
undo the cat and lamda sensor from underneath
then everything else can be done from above,
remove heat sheilds,
there a small bracket with a 14mm bolt head holding the manifold to the block, undo that,
undo the engine mount nut all the way,
undo the top manifold nuts
place a decent size piece of wood on a jack and using the sump or gearbox jack up the engine 2-3 inches (perfectly safe)
manifold should come out easily from above with a little giggle
reverse above steps to fit new one
hope that helps
hope that helps
Not yet Colin kept it standard till recently its still only done less than 16k. The manifold's the first mod.
Got some nice Ray's wheels,Greddy exhaust,Spoon TB,Password bits,Strut braces all to go on tho.
Did you find another or you gone for something else?
