Mileage correction for replacement cluster
Old Nov 24, 2010 | 08:01 AM
Imarriedmys2k's Avatar
Default Mileage correction for replacement cluster
Hi guys i was thinking of buying a new cluster for my s as mine is quite foggy from within nothing major but ive a bit of ocd now and then ive seen a pair on ebay but it has higher mileage, can this be corrected ? I know there is an obd2 port under passengers side dash im sure it can be done somehow dont want my odo meter jumping 30k more than what its currently showing lol
Old Nov 24, 2010 | 09:45 AM
martin j's Avatar
Some of the digital correction guys can make it read whatever you desire.
Old Nov 24, 2010 | 09:53 AM
AquilaEagle's Avatar
Administrator
I don't think simply replacing the cluster will change the mileage will it? Isn't the data stored somewhere? Or can you swap the parts that store the data between the new cluster.
Or do you really mean "Is there any way to clock an S2000?"
Old Nov 24, 2010 | 09:58 AM
Ultra_Nexus's Avatar
I'm pretty sure Mark Lammond can do it.
Old Nov 24, 2010 | 11:18 AM
PHo's Avatar
PHo
I would have thought it would have been saved in the ECU or something or other.
I know if I take my motorbike digital dash module out I can put another in and it reads the same mileage. This is because its saved within the ECU.
Old Nov 24, 2010 | 11:48 AM
s2konroids's Avatar
Doubt it will be in the ECU, its likely an EEPROM you'll have to read then write to.
Its probably located in the cluster itself, thus you will need an EEPROM writer/hardware to write the mileage.
Old Nov 24, 2010 | 12:25 PM
chrisr111's Avatar
Correct.
Chris.
Old Nov 24, 2010 | 02:33 PM
Si2k's Avatar
Milage is stored in the cluster, Mark Lamond modified my brothers when he fitted a S2000 dash in his DC2.
Old Nov 24, 2010 | 03:53 PM
ade73's Avatar
If its foggy,why not just take it out and remove the front to clean it?
Mark recently sorted the odometer display on mine as it had went off, and it is stored on the cluster.
He charged £80 for this and turn around was under a week.
Old Nov 24, 2010 | 10:19 PM
S2000_FUN's Avatar
