Minimum drop on Ohlins?
Old May 14, 2016 | 09:40 AM
Sipha's Avatar
Default Minimum drop on Ohlins?
What would be the bare minimum drop achievable with Ohlins DFV coilovers?
I'm not interested in stance and more importantly my driveway is such that I only just clear at standard ride height!
Thanks
Old May 14, 2016 | 10:51 AM
Define198's Avatar
don't know why you would not be able to run them at stock height?
Old May 14, 2016 | 11:04 AM
Sipha's Avatar
Hopefully I can!
Old May 14, 2016 | 11:13 AM
imc27's Avatar
You can. Mine are set at -25mm front, 30mm rear. Sometimes it looks as though it's not lowered at all:
Apologies for the lack of contrast - iPhone, black car, etc!
Old May 14, 2016 | 11:44 AM
noodels's Avatar
They will go 20mm higher than the specified & recommended 20mm drop from OEM.
Old May 14, 2016 | 11:59 AM
Sipha's Avatar
Great, so they will essentially run at standard ride height if need be
Old May 14, 2016 | 12:15 PM
noodels's Avatar
http://www.roadandtrackbyohlins.com/...MI_HOSMI20.pdf
Old May 14, 2016 | 01:30 PM
Nick Graves's Avatar
Yup - the kind of subtle drop that might actually improve handling & not ruin it.
Old May 15, 2016 | 03:30 AM
flanders's Avatar
The minimum recommended drop is 10mm as you can read from the manual posted.
You could probably go a bit higher than that though, but they advice against this since the damper body make come loose from the lower bracket.
Kshawn
Feb 17, 2019 02:14 PM
01S2KBROSNAN
Mid-A Swap Meet
15
Nov 29, 2009 02:45 PM
BoostinS2000
Feb 1, 2006 03:52 AM
prowlerartist
Aug 4, 2005 01:43 PM
Mole
Feb 16, 2004 07:45 AM
