UK & Ireland S2000 CommunityDiscussions related to the S2000, its ownership and enthusiasm for it in the UK and Ireland. Including FAQs, and technical questions.
I have read somewhere about a fix for this where the window is adjustable?? If you do a few searches I'm sure you'll find it. But, I had a similar issue with mine, so now, I lube the rubbers around the side windows and across the top where the soft top meets windscreen with silicone grease. Pretty much eliminated the problem for me. And you can get it for just a few quid, so worth a try if you haven't already.
yeh MB, i think for your problem i would say lube it. Altho im having some bother too b-u-t i think my problem is i need to adjust my roof catch so the roof is tighter onto the striker. I think mine is loose so i get water running into that little channel behind the seal and then it gets me a wet shoulder =[
I actually wondered about putting a length of soft silicon tube inside the leading roof seal, drill the visible top part of the tube with holes so that water can enter it and then feed either end down through the drain holes into either side of the screen.
Have greased the seals again for now.
I just wondered if you could plump up the window seals using a similar idea?
