Mis-shift
i'd like to see a marked speedo, my polo g40 had one, small marks on the speedo indicating the limiter in each gear, easy to know what gears are useable, i'm still not used to having to drop 4 gears on the motorway in the S
mine is a bit notchy going into gears. never had gate problems though
pretty sure it's down to clutch - sat at lights, engage 1st, the car kinda bangs as if the clutch is part-engaged.
that or it's the diff - diff seems to lockup on very tight corners and loose gravel (full lock, carpark type stuff) and one wheel always slips. no problems with engagement though!
Originally Posted by ian_6301,Jul 9 2008, 02:09 AM
You don't need a dash indicator.
3rd gear gives you 10mph for every 1,000rpm, ie: 30mph=3,000rpm,
90mph=9,000rpm
From there, you can work the rest out.
90mph=9,000rpm
The fact is I couldn't be arsed to qualify my reason at the time so I will add that it only occurs when I am not concentrating on my driving and not looking at the rev counter and I'm travelling in traffic. Thanks for the lesson though, I've printed out your post and it's now stuck to my windscreen so I can reference at what RPM and speed I must shift at but it still won't tell me what gear I am in so I am also considering employing someone to sit beside me whenever I drive shouting out the gear I am currently in.
[QUOTE=NineBolts,Jul 9 2008, 08:41 AM]I've noticed this when engaging 1st, although the gear engages easily it feels like the whole car moves a touch as the gears mesh.
