Missing bolt?
Old May 16, 2007 | 07:32 AM
B B's Avatar
B B
Originally Posted by MJ2k,May 15 2007, 11:03 PM
Nick,
Never understood myself until the weekend; shut the boot and heard a little tinkling noise of small stones falling from the rear bumber.
The large plastic part around the number plate which fits to the bumper (soffit as I have now learnt!) seems to have enough movement to allow smaller ones to move there & wedge in, causing small scratches with the movement of the car.
Gently flexing the surround & tapping the bumper seems to move them out - not sure how many I had in there, but all about 2mm max in size & blame it on a friend's driveway.
I never had a problem with it until the weekend, so dont worry if you dont have any stones - it all just adds weight afterall.
All I need to do now is insist my friend re does the drive, or I need a new friend!
Matt
Within a few days of taking delivery new car I discovered stones trapped and falling out from behind number plate surround.
I'm afraid my solution is a bit of a codge but it works. From underneath and behind the number plate I simply cleaned the plastic surrounding the lip that allows stones to collect and sealed the gap with plenty of black gaffer tape.
Access is not easy and I ideally would have liked to have filled the gap with black mastic
Will see how long my 'codge' lasts.
Old May 16, 2007 | 08:14 AM
nickrg3's Avatar
oh I see so that is behind the bumper... all clear now! So the square surrounding the plate is not part of the bumper. I think I understand.
Mine doesnt rattle though, think I'm stone free
Old May 16, 2007 | 08:41 AM
Ste_Nova's Avatar
no chance
Old Jun 6, 2007 | 02:53 AM
MJ2k's Avatar
Hmmm; new screw now in, but soffit still keeps moving down a few mm exposing small scratches. I need to re-tighten the screw every week.
Am I missing some clips to hold it in place, or do they all do this?!?!
Cant see anything there & really dont fancy taking it apart 'to see' as I am terrible at getting things back together again!
Mikey - looks as though you have taken yours fully apart, is there anything I am missing?
Thanks
Matt
Old Jun 6, 2007 | 03:01 AM
Nick Graves's Avatar
Preludes do it more dramatically.
The whole plate plinth drops about 1/2 cm if you knock it. It sort of 'snaps' back up again. I absent-mindedly went round and fixed all the 'Ludes in the Honda Institute at the visit.
The screws only seem to hold the lights in and lock it to a milky plastic inner carrier, which appears to connect to nothing..
I've looked at the diagram, but cannot work out HTF it's supposed to stay in place!
Old Jun 6, 2007 | 03:09 AM
MJ2k's Avatar
Thanks Nick - was getting extremely confused on that.
Even my neighbour came out last night asking me why I spend so much time touching my rear bumper!
At least I know 'it was designed like that, sir'.
Even started debating in my head if the weight of small stones was enough to make it drop down!
Matt
Old Jun 6, 2007 | 03:24 AM
mikey k's Avatar
There are locationing ridges on the bracing plate that hold the surround up that is it
Old Jun 6, 2007 | 04:13 AM
MJ2k's Avatar
Mikey, are these on the top of the bottom? - trying to work out where to push & in which direction.
Nervous of pushing too hard & causing all sorts of damage / popping the rear tow-eye cover out that needed to be epoxied in!
Matt
scruffeh
Nov 6, 2015 03:04 AM
eddw
Apr 8, 2014 12:29 AM
Flirt
Mar 28, 2012 08:25 PM
FISHHEAD
Mar 18, 2006 02:52 AM
zero_to60
Apr 1, 2004 01:06 PM
