Missing Hose on Intake Pipe?
Old Dec 18, 2011 | 02:45 PM
-McConnell-'s Avatar
Default Missing Hose on Intake Pipe?
Fitted a Refurbed TCT last week from a very nice gentlemen on here.
When removing the airbox i noticed that there was a hose missing from the instake pipe leeding upto the throttle.
Its worrying because it means I've been running the car for some time with effectively no air filter as this will act as a bypass for air.
Can anyone tell me what the missing pipe is and where does it lead to ??
Heres a pic...
Old Dec 18, 2011 | 02:55 PM
unclefester's Avatar
http://www.hondaoriginalparts.com/ho...block_03=23879
Part 7 is what you want i think.
And part 22 off this one.
Old Dec 18, 2011 | 02:58 PM
rob2.2's Avatar
Banned
AIR PUMP hose, pic 2 item 7
runs down towards the bottom rad hose/front headlight, there should be a metal plug (item 12) coming out of the silicone pipe that goes from the air box to the throttle body that has been ripped out.
metal plug Item 12
Air pump hose Item 7
Old Dec 18, 2011 | 03:05 PM
Yea this really helps guys.
Stupid Q, but what does the air pump do?
This was most likely Honda forgetting to put it back on when the clutch was replaced, found so many other things either loose or not attachted.
Old Dec 18, 2011 | 11:25 PM
I *think* it's there to help emissions when the car is started from cold although i could well be wrong.
Old Dec 18, 2011 | 11:29 PM
loftust's Avatar
Correct.
If you have no air pump (you need to remove the front bumper to find out) you should have the engine light on, unless a 'delete kit' has been fitted.
I can't see why they would disconnect this to replace the clutch, but have a look in the N/S/F corner to see if it is dangling loose.
Old Dec 19, 2011 | 02:53 PM
Nope cant find the loose hose anywhere...
Got me wondering how long its been that way.
I think I definetley have the air pump as I get the wine sound of it on start up for the first minute. (If that is that)
Why is it circ-ing air into the intake? and where is it getting the air from?
Old Dec 19, 2011 | 10:13 PM
mattie170's Avatar
It pulls the air from the the intake tube then pumps it into the exhaust via a egr valve that is at the back of the engine on the intake side. There is another flexible pipe after pipe ten that connects to it. The pipe that connects to the intake has either fallen off or it is still there just tucked out of sight
Itchy Dick
Apr 2, 2011 01:47 AM
jkuamoo
Socal Swap Meet
May 1, 2009 12:39 AM
STEVE PEARSON
Nov 5, 2008 02:03 PM
yellowknockers
Dec 15, 2004 01:51 AM
