More Problems!!!!
Old Jun 17, 2004 | 12:38 PM
Dan_DCDezign's Avatar
Default More Problems!!!!
Well here I am ... busy building the system, and trying to get the car ready for JAE ... and I now seem to have two problems, wondered if anyone can advice?
1) New today ... the drivers window wont go up on auto, it goes to the top, then goes half way back down again!!
2) Intermittent loss of power, and a nasty smell when I stop driving, only happen once or twice in last week or so, so difficult to diagnose.
3) Noisey engine, the clutch is noisey, it clunck when engageing, you can fell the car wobble when you depress the clutch, and the whole gear is kinda noisey. Only done 33k!!
Any thoughts? Or is it back to the idiots at Brayley Honda to see what bollox they can fob me off with this time?
Dan
Old Jun 17, 2004 | 12:45 PM
eSeM's Avatar
Have you got a Honda warranty with it?
If so take it to Norton Way in Letchworth.
Old Jun 17, 2004 | 12:47 PM
AquilaEagle's Avatar
Administrator
Use Letchworth Or Crown.
Drivers window:
Resetting the power window unit
Resetting the power window control unit is required after performing the following procedures:
- shutdown of the battery power.
- shutdown of the electric power caused by both No. 17 (20 A) and No. 8 (20 A) fuses.
- open circuit caused by disconnected 14P connector from the power window master switch.
- remove of the regulator, glass or glass run channel.
1. Make sure the glass is installed properly.
2. Turn the ignition switch OFF.
3. Remove the No. 17 (20 A) fuse in the under-dash fuse/relay box.
4. Turn the ignition switch ON (II) and hold on for one second, then turn it OFF. Install the No. 17 (20 A) fuse in the under-dash fuse/relay box five seconds later after turning the ignition switch OFF.
5. Make sure the driver
Old Jun 17, 2004 | 12:48 PM
Hello mate,
It is warrantied only had it a few months ... but with Braley (think we have spoken of how useless they are before ) they are an indipentant Honda Dealer to don't think the warrnaty is redeemable as Norton?
Dan
Administrator
What year is the car? Its not listed in your profile, as your not listed as owner.
Dependent on its age Has it had the clutch recall?
Old Jun 17, 2004 | 12:49 PM
Administrator
Your warranty is a Honda Warranty any dealership will honour it.
Old Jun 17, 2004 | 12:50 PM
[QUOTE]Originally posted by AquilaEagle
Drivers window:
Old Jun 17, 2004 | 12:51 PM
Old Jun 17, 2004 | 12:56 PM
eSeM's Avatar
Dippy yes!
...But they are a Honda dealer - Check out the Honda UK website and you will find that they are listed.
Old Jun 17, 2004 | 12:58 PM
Cool ... will drop them a line, they are a lot nearly that St Albans as well!!
How is your S ... you going to JAE?
Dan
