MY02 Alarm problem
Old Oct 22, 2009 | 12:43 PM
S2IM's Avatar
Smile MY02 Alarm problem
Hi All,
Searched and read the FAQ. FAQ good and helped me get the code for why the alarm is going off but not too many people with the same problem in search.
Basically I am arming the car (with hard top on) and after 15 minutes or so, the alarm goes off. Done it 4 times earlier, went out and read the flash code and it says 6 flashes which means "ignition turned on!?"
Well its not as the keys were on the coffee table
Anyone have any ideas!??! Is it goosed?
Car is locked by key at the moment.
Old Oct 22, 2009 | 11:31 PM
Wobbly's Avatar
How's your car battery? The alarm going off can sometimes be attributed to an old battery.
Old Oct 22, 2009 | 11:49 PM
S2IM's Avatar
Good point. Looking at it this morning it doesnt "look" old. Car is very low mileage for the year (23k).
Its just randomly started last night for no reason at all. I wonder if its with having the lights, heaters, etc on all the time now its winter it is draining the battery.
Old Oct 22, 2009 | 11:53 PM
Wobbly's Avatar
If your on the original battery then it's getting on a bit. I wouldn't like to say for sure that it is the battery, I don't want you to spend £40 on a new one for it not to cure the problem. Maybe somewhere like Quikfit could check it for you for free?
Old Oct 23, 2009 | 12:16 AM
lovegroova's Avatar
Old battery + colder weather = problems with the alarm.
Do get it checked first though.
Old Oct 23, 2009 | 12:19 AM
S2IM's Avatar
Thank you for the advice chaps. I set the alarm 45 minutes ago at work and not a peep... typical.
Ill get the battery checked somewhere locally this weekend.
Old Oct 23, 2009 | 12:29 AM
Wobbly's Avatar
Let us know how you get on, shop around for a good price on the battery too.
Old Oct 23, 2009 | 12:53 AM
lovegroova's Avatar
Part number is shown in this post. HTH.
https://www.s2ki.com/forums/index.php?showt...post&p=16859121
Old Oct 23, 2009 | 01:11 AM
Gizmo-R's Avatar
You can take them to most garages where they can do a drop test on the battery. This will give you an indication of how much beef is left in the battery
Old Oct 23, 2009 | 01:36 AM
S2IM's Avatar
Thanks Lovegroova
£40+ vat from Honda on part number above or £60 from Halfords. Honda will test mine before replacing as well. Will pop there on the way home.
Guy advised if the charge is low, the alarm will think the Battery has been removed and set its self off.
Noa230473
Nov 18, 2013 12:33 PM
PStanger
Sep 26, 2011 10:14 PM
Janeso
Dec 2, 2008 10:47 AM
euan
Aug 22, 2004 01:26 AM
