Need help REAL quick
Change the rear brake pads ... at work... at lunch time ... with somewhere to BE at 3 pm! Had to as the pads where down to the back plate !
Any way how to i get the piston to go back in the the caliper? its so push out and i cant get it to move back ?
you have to screw the piston back in, if you look at the piston face it has a cross on it you screw it in clockwise to put it back in the caliper. make sure that one of the slots lines up with the small pip on the back of the pad. When its all back together pump the brakes hard a few times to adjust them.
I have just done mine and they are hard to screw back in.
Originally Posted by Ruckus,Mar 28 2006, 12:37 PM
mine just wont move around !"
