is this normal
Old Dec 2, 2002 | 01:24 AM
zero_to60's Avatar
Default is this normal
when decelerating and going down the gearbox and I engage 1st while doing around 10mph - sometimes I can feel something move 'under the clutch pedal' almost as if something is moving on a mounting?? - does anyone else experience this
Old Dec 2, 2002 | 01:45 AM
rralston's Avatar
Haven't noticed anything like that - it's a bit jerky but most cars do that.
Does it do it every time ?
Old Dec 2, 2002 | 01:49 AM
zero_to60's Avatar
difficult to replicate consistently - I did have the same thing with my M3 but was told this was a characteristic of it's getrag gearbox
Old Dec 2, 2002 | 01:59 AM
rralston's Avatar
I get a bit of a clunk, and occasionally lock up on down shift, when my heel and toe doesn't quite match up !
Rich
Old Dec 2, 2002 | 02:05 AM
zero_to60's Avatar
thx for that - I will keep an eye on it and if it happens too often I might mention it at the next service
Old Dec 2, 2002 | 02:38 AM
gaddafi's Avatar
Banned
Tried this and nothing happened. Can't recall it ever happening in the S (or in my beemer) but slightly puzzled about why you want first at 10mph when slowing
I tend to come to a halt in second and go round corners in second or above and can't recall the last time I changed into first when decelerating. Maybe I'm getting old
Having thought about it, I am getting old
Old Dec 2, 2002 | 02:46 AM
zero_to60's Avatar
on my way to work there is a tight 90 degree right hander followed by a 90 degree left - the straight in between is not long enough to vtec in 2nd before needing to brake so a downshift to 1st is needed if you want 'to make progress'
Old Dec 2, 2002 | 03:00 AM
gaddafi's Avatar
Banned
Hope your tyres are warm
Old Dec 2, 2002 | 03:51 AM
S2000RJ's Avatar
I feel this quite often, a kind of kick through the clutch when the cogs do not mesh cleanly, or even it maybe the input shafts in the gearbox moving. I sometimes feel a kick through the through the gear level as well. I don't think it is normal, but I'm not sure how abnormal. If it worries you, see the dealer, if you trust them.
I think it is quite normal to need to change down to first when moving, especially in traffic. The manual says that 2nd should normally only be used above 14mph. I don't think it would be sensible to stop to select first everytime your speed drops below 14mph.
Old Dec 2, 2002 | 05:33 AM
zero_to60's Avatar
from many of the comments re dealers I am following the old adage if it aint broke don't fix it
jbeni96
Dec 1, 2007 09:29 AM
jfw432
Dec 4, 2006 01:52 PM
mikerpm
Sep 13, 2004 03:50 AM
silroan
Jan 3, 2004 12:20 PM
simons2k
Mar 4, 2003 01:52 PM
