O2 Sensor
Old Sep 23, 2005 | 03:38 AM
AquilaEagle's Avatar
Administrator
Default O2 Sensor
got a CEL today (been getting them, and resetting them - thought it was my cat) it turns out it is the O2 Sensor that needs replacing itself. Told the dealer not to bother, as it is going in for its 108k service soon anyway.
But thought - can I use a second hand one, like get it off a breaker? or are they cheap as chips anyway?
Old Sep 23, 2005 | 03:43 AM
simonprelude's Avatar
O2 sensor is
Old Sep 23, 2005 | 03:53 AM
LLOYDJ's Avatar
http://www.autopartswarehouse.com/mmp/hond...nsor~parts.html
Old Sep 23, 2005 | 03:54 AM
Fieldl's Avatar
How much ?????
As per tebs post on the GB thread, can you get a simulator to just send an all is fine signal ?
If not breakers is definately the way to go !
Old Sep 23, 2005 | 03:56 AM
Administrator
Thanks folks
Now i know what it looks like so i can see if any breakers got em
might also try HTG
Old Sep 23, 2005 | 04:16 AM
Amuse Boy's Avatar
Will contact you soon.
Old Sep 23, 2005 | 04:31 AM
Administrator
Thanks for the AB
Old Sep 24, 2005 | 11:26 PM
UK Paul's Avatar
Do you have a definitive list of all (if any more) failures in 108,000 miles....
Inpressive if this is the only failure (rather than warranty work).
Old Sep 25, 2005 | 03:23 AM
Administrator
Only other was my timing chain going paul, under warranty
I am still on original clutch too
btw The 02 sensor MIGHT be covered under my extended warranty need to check and try a claim
Old Sep 25, 2005 | 05:16 AM
MB's Avatar
MB
Member
AE - On turbo cars the O2 can fail very quickly. A lot of people use this place - www.cats-direct.com
For a fraction of the cost. I would prefer a breaker though, as they have the correct connector block on there. Lambda wires can't be soldered so you end up fiddling around a bit. Can be done though!
MB
cdelena
Dec 8, 2015 08:30 AM
dls91
Oct 15, 2015 10:22 AM
jshimer23
Jul 7, 2011 03:40 PM
tkeyyy
24
May 10, 2011 07:15 AM
