Odd Air Con Problem
Old Jul 18, 2013 | 04:14 AM
mattr's Avatar
Default Odd Air Con Problem
Strange air con prob here, unless I'm imagining it? When the car is moving (or stationary maybe with revs over certain amount) aircon is ice cold - but I'm getting the impression that when you come to a halt this isn't as cold or maybe not at all. Is there a drive belt that needs replacing/re-torqueing or a air con clutch problem that would happen engine speed wise related?
I'm sure its been like this for years and it had the air con refilled couple of years back, so not related to that either. (Or is it working fine and I'm expecting too much especially with the roof down)
Ta
Matt
Old Jul 18, 2013 | 04:19 AM
BenRNBP's Avatar
Funny you should say that mine seems to do something similar but I attributed it to the fact I've not got around to getting it vacuumed down and recharged.
Old Jul 18, 2013 | 04:24 AM
simonix's Avatar
Mine also does this! It also makes a hissing type sound under load sometimes! :-(
Old Jul 18, 2013 | 07:38 AM
Wellwibb's Avatar
My air con clutch has just gone, I went to Honda and they want 600 for parts and labour to fix it.....
Old Jul 18, 2013 | 08:31 AM
loftust's Avatar
They are fairly easy to change and can be picked up second hand for about £50.
Sent from my GT-I9300 using Tapatalk 2
Old Jul 18, 2013 | 08:38 AM
mattr's Avatar
£600 Think they're having a laugh there... Does your air con not work at all?
Old Jul 18, 2013 | 08:41 AM
Wellwibb's Avatar
Yeah, I told Honda I wouldn't be using them to sort the issue. I haven't started looking into parts myself but it's something I will do myself eventually.
Old Jul 18, 2013 | 08:42 AM
Wellwibb's Avatar
My air con works fine. I just have a pretty loud rattle coming from the unit. I will sort it myself when I can spare the time.
Old Jul 19, 2013 | 04:21 PM
E4RTH WORM JIM's Avatar
Is the condenser fan working?
Old Jul 27, 2013 | 01:34 PM
mattr's Avatar
Had another quick look at this. Condensor fan is working (although I did see it switch off once whilst idling).
If stationary, and you increase the revs to ~1500rpm, you can definitely feel the fan air stronger and cooler in the car, but I don't seem to hear anything different (ie compressor/fans changing) ??
