Headlight stress cracks - anyone else?
My headlights on my 2006 car have been gradually deteriorating. It’s a low mileage car which has been garaged. Hasn’t had a lot of use with the headlights on due to being used on sunny days.
Ive searched the forums and it seems this is not so common, I have found a few cases on the US forums. Its suggested to be stress cracks, caused by the extreme heat from the headlights.
I have just about accepted that I need to buy some new OEM lamps to resolve this.
Before I do, have
others here had the same issue, and found any other solution?
davida
Before I do, have
davida
Is it over the beam pattern area of the lights? If not i'd get them polished up and then regular wax / sealant. Mine ( 2004 car) had started to go that way but more like your right light than the left ... the left one looks weird.
https://www.s2ki.com/forums/s2000-bo...p-diy-1196890/
If you've not seen the price of OEM light units yet and no, you can't buy the lenses seperately.
martin j (04-20-2021)
Having seen the price that used and often damaged headlights have been achieving on ebay, I was pleasantly surprised at the quote for a pair of new from Honda. So I decided to treat the old girl and ordered a new pair earlier today!
Change from a 1500 quid?
I use a hairdryer to split mine but brand new OEM is best if you can afford it.
It's a clear unit though , no focusing via the cover as all of the beam work takes place in the HID projector unit.
If you haven't done it before, slow and steady with a hairdryer works. Gentle even pressure to split them once the goop softens. The longest part of the job is digging all the old sealant out of the channel.
That's what i used to replace it, it's also perfect for resealing door weatherseal plastic to the metal door frame.
