OEM studs, are they long enough?
Hello, I've just fitted a BBK to my car!
In order for the wheels to fit (rota slippy's 17/7.5"/+45) I need a 5mm spacer. When I fit the spacers and wheels onto the hub, the oem studs don't show much thread anymore.
My question is: what is a safe limit before the studs need to be replaced? I can get four full turns on the studs until the nuts are fully tight. Would you think this is sufficient?
I read somewhere there is a rule of thumb when doing this, which depends on stud diameter /thread type?
Thanks
Thanks
I have been using 5mm spacers on my front wheels for a few years now without changing to longer studs.
I remember reading that you need 5 full turns to be safe and I get 6 or 7 with a 60 degree tapered nut.
Have you still got the mugen's on? or a different wheel, with spacers?
Member
Have you got a pic?
In the piping world we always want the stud flush with the nut as a minimum, or preferably 2 threads showing.
This is tricky with a wheel nut as the stud doesn't come out of the nut.
You can measure the exposed stud length with the wheel on and measure it with a caliper, and then measure the depth of the nut too.
Or count the threads.
But if you have lost 5mm I would be quite careful.
I agree with MB. I would not consider 4 turns to be enough.
No matter how many threads tall a nut is, it is correct that the majority of the load will be taken by the first three to four threads, however this would be at best 75-80% of the total load, with the reminder loaded in 5-6 and beyond in decreasing amounts.
Also bearing in mind that your studs/nuts are not new and will have been slightly deformed from previous tightening, the later threads would be relied on more than in a new nut.
They will work, but I would not be happy with safety factor you have now. I would change them.
Gav
Gav
Thats good enough for me.
You both have confirmed what thought/new, thanks!
I have never changed studs on a car before so don't know how much work is involved.
When I removed the OEM disks and calipers it looked like the studs have been pressed through a hole in the hub? May be it would be easier to buy J's racing hubs?
I've seen H&R do spacers though with longer studs as a kit, so it must be possible?
Which would anyone recommend? taking into account time/money.
Anymore advice on extending the studs is now welcome
