Oil change at honda
Old 02-12-2019, 01:06 AM
Brailer's Avatar
Default Oil change at honda
Booking in for oil change at honda. When using their online booking form it says tick to recalculate with specialist oil. Now I'm assuming it u book with honda they will use the correct oil for the car? I'm booking with honda basset in Bridgend.
John
Old 02-12-2019, 01:13 AM
UK Moderator
lovegroova's Avatar
So long as they use the correct grade (details on loads of threads all over the site) you'll be fine. Call them and ask if you're worried.
My dealer has always used the correct oil.
Old 02-12-2019, 01:43 AM
Brailer's Avatar
Spoke to garage. They said Castrol edge 20 will be used?.
Old 02-12-2019, 01:53 AM
gingerphil's Avatar
That's not the grade that I would have chosen, but I guess this doesn't want to turn into another which oil thread.
Out of interest, what's your reasoning for going to a main dealer?
Old 02-12-2019, 01:57 AM
UK Moderator
lovegroova's Avatar
There's no such thing. Get the exact details from them.
Old 02-12-2019, 02:14 AM
gingerphil's Avatar
I assumed 0W-20.
Old 02-12-2019, 03:03 AM
Brailer's Avatar
Originally Posted by gingerphil
I assumed 0W-20.
This is the oil they have said would be used.
Old 02-12-2019, 03:06 AM
UK Moderator
lovegroova's Avatar
Get them to use 5w40
Old 02-12-2019, 03:36 AM
flanders's Avatar
You can assume they will use the wrong oil and also charge a lot more for it than if you bought it yourself.
Probably going to use the wrong oil filter and not torque it correctly as well
Old 02-12-2019, 04:13 AM
gingerphil's Avatar
If you're lucky, and an improvement on this, they won't do anything at all.
Quick Reply: Oil change at honda
