Origin hardwiring
Old Jun 2, 2004 | 04:09 AM
JMP's Avatar
JMP
Default Origin hardwiring
I'm planning to do this soon into the free connect (1 of them) in the fuse box but how do I ground it??
The connect cables don't have a ground for plugging/attaching.
I'll put a 1A inline fuse in though
Jonathan
Old Jun 2, 2004 | 04:47 AM
simmo's Avatar
If you lok futher up on the drivers side foot well on the right hand side there is a grounding point there.
This is what i used for the bell and RA.
Just make sure you dont drop the screw.
Old Jun 2, 2004 | 08:26 AM
JMP's Avatar
JMP
Thanks.
Anyone know how I can create a wire to ground it though?
The B2 cabling does not obviously come with a specific wire for grounding.
Old Jun 2, 2004 | 09:47 AM
markS2kcU's Avatar
Originally posted by JMP
Thanks.
I'm sure it does, just cut the fag lighter plug off and you got 2 wires in there one + one - .
bigfecker's Avatar
You use the black wire to the bolt that Simmo mentioned - thats it.
Old Jun 4, 2004 | 02:12 PM
JMP's Avatar
JMP
Here's what you got when you lop off the ciggie lighter plug:
These wires are minute and a decent wire stripper is required
Soldered ground loop to the blue cable, in line 1A fuse (in holder) and female quarter inch spade connector on positive red wire (it is soldered under the insulation tape )
Connected to gound point R footwell above the bonnet release
Positive connected to ignition on free connect in fuse box
It works
Dash mounted GPS antenna
The antenna cable and power cables slot behind windscreen and down between dash and door in a handy gap.
Jonathan
Old Jun 5, 2004 | 12:28 AM
AquilaEagle's Avatar
Administrator
Nice one JMP - I'm doing this next weekend
Old Jun 5, 2004 | 03:30 AM
AdrianEagle's Avatar
And he might do mine the following week-end! Otherwise no birthday pressie!
Old Jun 5, 2004 | 08:38 AM
bigfecker's Avatar
Nice photos, you went for the mounting on top of the dash option, I mounted mine in front of the vent.
Now you see it:
Now you don't:
To do this I tightend up the flap (see below) so it was at a fixed angle and then just fixed it in place with the supplied double sided tape, there's enough surface area in the vent to give it a good fix.
Also did you know you can take the cradle apart and make the wire come out of the right side rather than out of the left side, you may of done this, cant tell from your photos.
Old Jun 5, 2004 | 11:13 AM
Administrator
OOh thats useful to know - I didnt know that mat
