Paint Job - dust imperfections
Originally Posted by gaddafi,May 14 2009, 10:29 AM
I'm not sure that I follow the logic that a cheap paint job would be as good as an expensive paint job
There are cheap harnesses and very expensive harnesses. If the cheap ones split as you launched through the windscreen I doubt you'd be thinking at least you'd saved a few quid...
An extreme example but if you agree on a price for work then it should be an acceptable quality. If the paint shop had said that for
Banned
[QUOTE=Bassoctopus,May 14 2009, 07:21 PM] Rear wheel arches had started to rust a bit and front wheel arches had stone chip rash which was also starting to rust.
I was told for a proper job all 4 wings would need painting and that would cost
Well you've got first hand experience of their work before, so if you politely say that the first bit of work on the wing was of a higher standard (and that you want to keep using them in the future/recommend them to others), then hopefully they will be accommodating...
Banned
Originally Posted by Bassoctopus,May 14 2009, 08:16 PM
As stated above, I've had stuff done before by the same guy/place, including a wing on the S and it was close to perfect.
in which case will you want all four wings repainted?
this guy must work on some margin
