Pipe from intake???
The standard intake has the pipe from rocker to intake which I've deleted, the 2 small lines running to what I assume is a sensor or some sort of idle air valve I lengthened and car runs fine but what I don't get is the pipe running on the other side of intake down to outside the engine bay into the small unit and back up and into the back of intake.... what is this for and can I delete it without any issues? I took off the one from intake and it's running fine any help appreciated cheers Phil
You probably want to keep the crank case ventilation ( the one you've already "deleted"), and the other one you're talking about sounds like the Secondary Air Intake pump - you can delete but you need a kit - see the For Sale section; https://www.s2ki.com/forums/uk-irela...e-kit-1129089/
project*stealth
Dec 3, 2011 01:38 PM
