power steering belt
I've had this sometimes, a wee rev cures this.
I have noticed this occasionally for a couple of seconds at start up, but as martin j says, blip the accelerator and it goes away. It's been like this ever since I've had the car (> 2 years,) so just assumed it was a 'feature' of the car. It certainly hasn't got any worse.
Just after starting, the battery power will be low.
You just drew over a hundred amps turning a cold engine with oil like treacle.
Thats why its sluggish - electric power assist.
Originally Posted by Heinz '57,Dec 1 2010, 11:28 PM
Let us know the result.
When belts slip, they tend to continue to slip.
Increase the rpm to 2,000 & see if it improves. The alternator ought to be driving it direct by then.
It could as easily be stiction in a bent steering rack.
Also if you are going out and starting the car on the drive and going nowere you will drain the battery and make matters worse. Best to leave it till you can drive the car.
Originally Posted by m1bjr,Dec 2 2010, 06:18 AM
It's meant to be like that.
Centre weighted so the steering isn't silly light.
