Private plates
I've had a butchers on the DVLA site and, although there's all the guidelines about Suffixes, prefixes, fonts, spacing yadda yadda yadda, I can't find anything that tells you what you can and cannot have as a private plate (apart from the not making it appear younger than it is)
So seeing as a lot of the cars here have S2000 this and S2K the other...thought I'd ask here
How do I go about sorting S2K FTW or S2K GJ or something?
(bunged the possiblities into AA's car data check as a first pass and they show up as not registered).
![biggrin.gif](https://www.s2ki.com/forums/images/smilies/biggrin.gif)
![](https://www.s2ki.com/forums/images/s2ki/ranks/gold_member.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-3yr.png)
Have a look here:
http://www.dvla-som.co.uk/home/
You can enter a particular search string and see which plates it has available.
[QUOTE=grahamb,Jun 3 2005, 04:28 PM] I've had a butchers on the DVLA site and, although there's all the guidelines about Suffixes, prefixes, fonts, spacing yadda yadda yadda, I can't find anything that tells you what you can and cannot have as a private plate (apart from the not making it appear younger than it is)
What else do you want?
There are 'dateless' plates as well which are the 'proper' private plates and tend to be expensive and difficult to find what you want as all the best ones will be taken.
dvla-som.co.uk is the best place
you cant have S2K FTW as there are to many letters, you could have S2 KXX with XX being whatever you want if available, see link below.
http://www.dvla-som.co.uk/home/en/Search/p...91&y=8&start=20
{bugger beaten to it}
Yeah that's the kind of thing I was getting at. I know you can get certain "normal" plates that spell out certain things and whatnot, like S20 0DJ for example, that I saw the other day.
I'm on about what I think of as "proper" private plates as well
The S2000 plates are just normal S reg plates with an O in them, ie S200 O** where the * is any 2 letters.
Try the Newreg link above, the site is an arse to navigate but you get better results than the DVLA one.
Well yeah, but to give an example :
A1
That's not a prefix, suffix or current but IS a valid licence number iirc.
edit - which are in fact "dateless" as Neil mentioned. Ta for the NewReg link
A1
![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
