Problem with Origin b2
This has happened a couple of times now...
Driving along, keepin' it real in the S, safe in the knowledge that my trusty b2 is watchin my speedin' behind...
After about 40 minutes the b2 starts flashing between the normal speed display and the satellite search display, about twice a second. So I pull it out of the cradle and slot it back in and it then can't find satellites for the remaining hour of the journey.
Lovely sunny day on both occasions and no long tunnels or anything.
Any ideas? Anyone seen this before? Maybe a need a new cradle, or satellite antenna?
Is the B2 unit properly secured in the cradle? I had a very similar problem - the stiff suspension and the less-than-ideal roads by me meant that the unit was jumping around in the cradle and losing its connection. Once the connection was lost, it was often difficult to get the thing to lock back onto the satellites.
Origin will fit stronger magnets for you apparently. I couldn't be arsed to send mine away to have it done (they wouldn't send them to me to fit myself) so I resorted to holding the B2 in place with an elastic band tucked under the left hand side of the cradle and over the top right hand side of the unit.
Works a treat, if a bit unsightly......
Mine did this a couple of times about two weeks ago. Has never done it since so I wonder if it was either dirty contacts on the cradle connection or perhaps some atmospheric conditions interfering with satellite reception.
Otherwise its been fine, and its been great at reminding me about the 3 new SPECS zones on the A77 when I go down to Prestwick for golf.
Originally Posted by JEVON,Jul 19 2005, 07:14 AM
Not sure about the set up of the OB2 but where is the GPs signal reciever?
Strange. Mine has also started doing that immediately after my last upgrade - about 2 weeks ago.
Removing from cradle / replacing appears to resolve it (after a several attempts) but I wouldnt simply presume that its bad contacts because of that - it may be simply the act of restarting it (I can never be bothered with the on/off button!) - sounds more like a s/w prob to me...
