Problem with phone charging from lighter socket?
I had some problems with a a 12V connector extension cable being used with a 2.4V charger, but I have got everything working using an Aukey Quick Charge 2.0 and USB cable.
https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1
Note that you must use the yellow qc2.0 connector for the charging to work, charging does not work as well with the green connector.
This is with a Sony Z3/5 compact.
The other option would be to hard wire in a connector, as explained in this post in the FAQ (you'll need to scroll down a bit) https://www.s2ki.com/s2000/topic/301...st__p__5798525
Originally Posted by flanders
Have you tried different cables as well?
Thin crappy ones, or really long decent ones might not provide enough current to keep charging if you are using the phone.
I got one of those Aukey quick chargers and it's been working good in my car.
Yep I'll have to say goodbye to the radio as well. Looks like I've got some quiet and spartan late night journeys ahead of me :0(
you're trying to charge the battery while hammering it, it won't go up very quickly
Originally Posted by richmc' timestamp='1472853754' post='24053914
[quote name='Nottm_S2' timestamp='1472852825' post='24053906']
If you're draining battery on gps and screen i think that might be as good as you get
[/quote]
It's OK I knew what you meant.Incidentally I also considered the possibility that the battery wouldn't charge very effectively if it was hot. Attaching it to the air vent and turning on the A/C dispelled that as a possible cause of the prpblem.
