Problematic CEL relating to primary O2
Old Mar 30, 2013 | 05:54 AM
  #21
Spies's Avatar
Is this one the correct sensor for my 55 plate?
http://www.ecolambda.co.uk/main/ecos...item=250-24391
Old Mar 30, 2013 | 12:53 PM
  #22
Spies's Avatar
Anyone? Please?
I stopped earlier to drop mum back home and on starting it again the idle was really rough, the car wouldn't move without kangaroing all over the place. Ended up having to turn it off and start it up again.
Old Mar 30, 2013 | 02:00 PM
  #23
Dracoro's Avatar
Have you tried my suggestions? No point spending money before trying the free options.
Also, care with odb readings, the O2 sensor may be registering a fault that may be caused by something else (e.g. over fuelling etc.)
Old Mar 30, 2013 | 02:03 PM
  #24
Nottm_S2's Avatar
Pretty cheap compared to oem
The site you're on lists this
http://www.ecolambda.co.uk/main/ecos...item=250-54023
For
S2000 2.0 AP F20C 09.05 on Front 250-54023
I would ring em with your VIN
Old Mar 30, 2013 | 02:30 PM
  #25
Spies's Avatar
Haven't checked the IACV yet will take a look on Monday.
Old Mar 30, 2013 | 02:33 PM
  #26
Dracoro's Avatar
And cleaned the inlet butterfly?
Old Mar 30, 2013 | 02:49 PM
  #27
Spies's Avatar
Yes, I only got the code reader today so pulled the code and had to use the car, I'm at the girlfriends for the weekend now so I can't do anything more with it.
As for the different lambda sensors, aren't the more expensive (wideband) ones only used on DBW cars?
Old Mar 30, 2013 | 04:06 PM
  #28
markforrester99's Avatar
36531PCX014 is the part number for a 2006 non DBW car
http://lambdapower.co.uk/partsearch/...Dlist=LC-10064
searching for that part number came up with that link above listed as direct fit.
Old Mar 31, 2013 | 03:27 AM
  #29
Spies's Avatar
I've read that the Bosch lambda sensors fail after a few months. Something to do with the voltage they run at.
Old Mar 31, 2013 | 04:52 AM
  #30
Well you can either buy that one, or buy a denso one from Rockauto and have it shipped over. The other option is to bend over and accept the OEM price.
