Problematic CEL relating to primary O2
Old Apr 2, 2013 | 10:32 AM
  #31
Spies's Avatar
Still the same after some cleaning, cleared CEL and it came back after a couple of minutes.
New lambda it is...
Old Apr 8, 2013 | 11:07 AM
  #32
Spies's Avatar
And it's fixed
Old Apr 11, 2013 | 12:12 AM
  #33
Spies's Avatar
CEL has returned, this time with P0135 which is to do with the heater circuit.
Any ideas anyone?
Old Apr 11, 2013 | 12:31 AM
  #34
unclefester's Avatar
That sounds more like a duff wire / bad earth in the circuit if you've already changed the sensor.
Old Apr 11, 2013 | 12:35 AM
  #35
Irish TuneR's Avatar
Searchy search yielded this....
Old Apr 11, 2013 | 12:39 AM
  #36
Spies's Avatar
Any way to verify my heater driver is good?
It's also cutting out at idle, I wouldn't have thought it would do that though as the lambda voltage is still going from lean to rich.
That's talking about the secondary.
Old Apr 11, 2013 | 12:41 AM
  #37
Well .... it's a new part! Did you crimp the wires or use the existing plug?
  #38
Spies's Avatar
It already had the plug on it, it was a direct fit replacement.
Old Apr 11, 2013 | 12:43 AM
  #39
I would be tracing the wire back to see if you have a break in it - also check the condition of the wires in the car part of the plug - check that the connections are nice and clean.
Old Apr 11, 2013 | 12:53 AM
  #40
Spies's Avatar
I will pull it apart tonight and give the contacts a good clean. Hopefully that resolves it.
