Pulling to left when lifting off
Hi,
Just swapped my 16's over to facelift 17's and noticed its pulling quite a bit to the left when lifting off the accelerator. I know the Geo needs doing for sure, as I've recently fitted coilovers - so I'm assuming it's that. But other than a sticking rear brake, is there anything else I can check?
Obviously I've checked the wheels are actually on straight
Far more likely to be a sticking caliper IMO. Check if you have a hot wheel after a bit of a drive.
But if it's happened exactly the same time as the coilover swap, I think you need to do your geo.
classic signs of rear puncture
