Quietcoat application progress
Stuff you'll need to remove seats and carpet:
12 and 14mm sockets (for seat bolts and seatbelt anchor point)
cross head screw driver for kick panels
assorted flat blade screwdrivers to lever the damn plastic fasteners out (approx ten each side)
I've done my complete boot with dynamat so i will only need enough to do the floor pan and i might well use it as an extra on the doors, already stripped the skins and fitted dynamat on those but could not get to all bits, i have had th ecarpet up before so could do it all over again but with my car coming home soon i dont wish to do it straight away. still got to get hifi finished and loads of other bits fitted so i can drive it.
I've dynomatted the doors as well under the skins - I've not dynomatted inside the door panel, is that what you intend to do with the quietcoat? Sounds like a sensible idea as it would be relatively easy to get a brush in there, although I want to get the coats done on a single day in the Summer I think.
EDIT: tapping the floor pan I agree with other quietcoat users' identification as the area over the cat sounding particularly thin - https://www.s2ki.com/forums/index.php?showt...dpost&p=5251913
