Random Alarm
Old May 23, 2009 | 09:26 AM
Kiyya's Avatar
Thumbs up Random Alarm
For some reason the alarm on my MY00 S seems to be going off without warning. There doesn't seem to be any pattern to why it might be going off - sometimes it goes off after I've washed it, a few nights ago it went off in the middle of the night, and it's just gone off again today after a quick drive to the shops with the top down.
At first the Clifford engineer where I work thought it might be the Ultrasonics, which we've now disconnected. But doesn't seem to have made a difference. I've had to resort to just locking it with the key and not arming it - which I'm really not happy about.
Anyone else had the same problem, or have any suggestions?? I'm going to replace the alarm once I get paid, but would welcome any help or advice in the meantime as it'll be two weeks at least until I can buy it and get it fitted.
Cheers,
Sam
Old May 23, 2009 | 11:24 AM
jimpom23's Avatar
Have a search on here for Alarm Test or similar...basically it is a sequence of buttons you can do then you read the blinks on the light and it 'tells' you which sensor is dodgy - i.e. roof/bonnet/boot etc
Old May 23, 2009 | 02:10 PM
Kiyya's Avatar
Cheers for that mate. Not been able to find the sequence in any of the forum posts, but found someone who has a PDF of the alarm manual.
Sam
Old May 24, 2009 | 12:14 AM
FunBox's Avatar
Usually it's the bonnet sensor switch that gets rusty and covered in crud...
Old May 25, 2009 | 12:23 PM
vfast1's Avatar
You may need a new battery. Is the battry old?
Old May 26, 2009 | 04:01 AM
tysonthenewb's Avatar
If it goes off after you've washed it then it is likely to be that the alarm sensor under the bonnet (front driver's side) is a bit corroded and needs cleaning up with a bit of sanding followed by applying a bit of grease to stop water getting in etc...
I had this problem a little while ago, if you do a search on here there are some good threads telling you step by step what to do. I'll try and find one for you now...
Old May 26, 2009 | 04:06 AM
Here you go, see half way down
https://www.s2ki.com/forums/index.php?showt...&#entry13694882
HTH
g-tec
Jun 11, 2008 07:42 AM
Mbudz
May 10, 2008 03:27 PM
tflpunk
Feb 8, 2008 12:21 AM
sammyc
Nov 19, 2004 01:49 PM
trendy26
Mar 2, 2004 07:45 AM
