rattle
Old Mar 21, 2007 | 02:18 PM
noodle's Avatar
Default rattle
Hi guys,
had the mysterious rattle again, engine warm at about 3500-4000 revs and i got what sounds like a slappy constant rattle for about a minute and then it stops. doesnt do it below these revs nor as it hits the v-tec. This has only happened twice in a couple of weeks. Could it be tensioner? maybe a heat shield. Sounds like its coming from the centre of the engine bay just in front of the dash. Any ideas would be much appreciated. Thanks
Old Mar 21, 2007 | 02:37 PM
MB's Avatar
MB
Member
You need to get the bonnet up and get your head under there.
Use the throttle on the manifold to rev the car and listen...
Old Mar 21, 2007 | 02:43 PM
noodle's Avatar
Thats the problem, its so intermittent that by the time i pull the car over and get the bonnet up its gone. Also it only seems to do it under power when i'm moving.
Old Mar 21, 2007 | 02:44 PM
MB's Avatar
MB
Member
Could be the cat or a heat shield as you say.
Get under there with a torch and start pulling at things
Old Mar 21, 2007 | 02:47 PM
noodle's Avatar
i'll give it a go. Hope its nothing too serious, guess it would be more regular if it was anything major. Cheers
Old Mar 21, 2007 | 03:06 PM
P 1's Avatar
P 1
Might be something simple - have a look at this:
https://www.s2ki.com/forums/index.php?showt...dpost&p=7524568
Toms1989
Aug 18, 2012 03:11 AM
defiant
Oct 29, 2011 06:29 AM
rocy
Oct 19, 2010 07:46 AM
nashby
Aug 5, 2007 05:20 AM
Horza
Nov 7, 2006 05:15 AM
