Rays
Old Mar 10, 2010 | 02:57 AM
The Loon's Avatar
Default Rays
I've been looking at getting a set of wheels. I've contacted the UK distributor who has sent me details of the following wheels which are within my sub £1500 budget:
1. G07wt http://rays-msc.com/wheels/index.cgi?d=35 17x7 + 17x9 fits straight on
2. 57 maximum http://rays-msc.com/wheels/index.cgi?d=28 17x7 +17x8 (17x9 fits with a small arch mod)
3. 57 Accelerate http://rays-msc.com/wheels/index.cgi?d=24 17x7 +17x8 (17x9 fits with a small arch mod)
I've never owned a set of Rays so any advice/recommendations appreciated
PS - If you have a set of Rays that want to sell
Old Mar 10, 2010 | 03:13 AM
chrisr111's Avatar
Can you state what the offsets of the various wheels are?
Chris.
Old Mar 10, 2010 | 03:24 AM
punchdrunk's Avatar
You want to be going for;
17x7.5 ET50 - Front
17x9 ET63 - Rear
I like the 57 maximum out of the choices above.
I've had several sets of rays wheels - the forged ones, but their casting process is amongst the best out there so there shouldn't be any cause for concern.
I'm guessing weight will be similar to 04+ 17's
Old Mar 10, 2010 | 03:25 AM
mdjohnso's Avatar
Those first one's look to be the wrong PCD to me and they come in very low offsets....
57 Motorsport G07WT 17" Euro Spec Alloy wheel
SIZE FACE TYPE CENTRE DEPTH(MM) OFFSET PCD BORE PRICE
17 x 7.0J FACE-1 18 +46 5 x 112 57Φ £253.21
17 x 8.0J FACE-1 36 +38 5 x 98 58Φ £267.71
" " " " " " +38 5 x 100 57Φ £267.71
" " " " " " +43 5 x 120 72.5Φ £267.71
17 x 9.0J FACE-2 21 +45 5 x 120 72.5Φ £276.22
Old Mar 10, 2010 | 03:26 AM
The Loon's Avatar
Chris.
Chris- please see below
1. G07wt offset +43 front +63 rear (specific to spoon car)
> 2. 57 maximum offset +43 front +43rear (17x9 would be +38)
> mod)
> 3. 57 Accelerate offset +43 front +43 rear (17x9 would be +38)
> mod)
Fitting 17x 9J wheels in a +38 is possible here is a trackday s2000 with 17x9+38 all round
http://farm3.static.flickr.com/2525/412661...08f954882_o.jpg
Old Mar 10, 2010 | 03:32 AM
chrisr111's Avatar
If you're set on picking from those you have listed I would go for the G07wt. However, +43 may rub the arch liners if you lower the car and run a sensible geo.
The other lower offset wheels will fit with arch mods and/or lots of negative camber but handling will probably suffer.
Chris.
Old Mar 10, 2010 | 03:41 AM
The Loon's Avatar
Thanks chaps.
I will probably wait for a set of CE28N or RE30 to come along. There's not much point in spending over a grand for a set of wheels which wont sit properly.
Old Mar 10, 2010 | 03:50 AM
punchdrunk's Avatar
Originally Posted by haroonsarwar,Mar 10 2010, 12:41 PM
Thanks chaps.
Good luck
Old Mar 10, 2010 | 03:56 AM
The Loon's Avatar
Thanks for the tip
Old Mar 10, 2010 | 04:29 AM
propete10's Avatar
Personally I like the 57 accelerates the most mate.
You should of said you were planning on this, I'd of bought your wheels of ya! =D
