Rear ABS sensor
Old Feb 19, 2016 | 11:12 AM
Dillon_93's Avatar
Default Rear ABS sensor
Hi guys, what's the best way to get the rear ABS sensor out without breaking it? I hear that these are prone to breaking, I've undone the 10mm bolt but it seems stuck in there.
Old Feb 19, 2016 | 11:23 AM
Define198's Avatar
what do you need to take it out for? can you unclip it from the source? that's what i had to do with mine on the front when i did a wheel bearing, practically impossible to get out without a high risk of damage
Old Feb 19, 2016 | 11:33 AM
Dillon_93's Avatar
I need to change the hub due to an accident
Old Feb 19, 2016 | 11:48 AM
Daytona-Dave's Avatar
socket with an extension on the face side just small enough to go through the hole and give it a few sharp taps with the hammer
Old Feb 19, 2016 | 12:11 PM
tozerman's Avatar
I tool all 4 of my ABS sensors out last year, undid the little bolt and prized them out with a flat screwdriver no problem, when I refitted them I cleaned the hole, then cleaned the outside of the sensors with some fine abrasive paper and refitted with some grease and bobs your uncle.
Old Feb 19, 2016 | 12:44 PM
very lucky if you prized them out with a screwdriver it's the most common way to break them
Old Feb 19, 2016 | 04:26 PM
Toms1989's Avatar
Definitely. I followed DD's advice, with the driveshafts removed, get a 13mm deep reach socket that sits over the probe but around the base of the sensor, a few good hammer taps and they came free
Old Feb 20, 2016 | 12:19 AM
tozerman's Avatar
Very true I was lucky, having said that I took it real slow used plenty od wd40 and was helped by the fact my car has had very little wet use in its life so there was no corrosion to sieze the little bastards in
Si2k
Dec 27, 2008 07:13 AM
kMfromLA
Jul 19, 2006 03:35 PM
desperates2k
Sep 22, 2003 06:24 PM
desperates2k
Sep 20, 2003 10:19 AM
desperates2k
Sep 19, 2003 06:43 PM
