rear brake calipers
rear brake calipers
Hi all,
Both rear brake calipers had partly seized took it my mechanic mate managed to free nearside & he said keep an eye on the o/s , took it out today did less than 10 miles got home and the o/s was smoking even the wheel was god damn hot, where is the best place to get new calipers decent ones , or is it worth getting a repair kit ?
thanks in advance for your advice. Mick.
Brakes international are a reputable supplier of overhauled, OEM nissin calipers.. Got a pair on the back of mine and all is well again Demand is high for these though, so you may not always get them straight away.
Worth a phone call to them, always been very helpful when I've spoken with them
Yep, demand for rear calipers is high so you may need to ring round a few places.
I replaced mine recently. Armed with the part numbers Toms1989 provided in a separate thread I set about ringing around motor factors. I found myself a pair of rears and fitted them. Easy to swap over and I would recommend doing this instead of spending money on a repair kit. Mine cost me £83 each, but this will vary depending on which motor factor you get them from.
Part numbers:-
AMK:-
RR LEFT TCA3069
RR RIGHT TCA3070
SHAFTEC:-
RR LEFT BC8896
RR RIGHT BC8896R
BRAKE ENGINEERING:-
RR LEFT CA2214
RR RIGHT CA2214R
Part numbers:-
AMK:-
RR LEFT TCA3069
RR RIGHT TCA3070
SHAFTEC:-
RR LEFT BC8896
RR RIGHT BC8896R
BRAKE ENGINEERING:-
RR LEFT CA2214
RR RIGHT CA2214R
Part numbers:-
AMK:-
RR LEFT TCA3069
RR RIGHT TCA3070
SHAFTEC:-
RR LEFT BC8896
RR RIGHT BC8896R
BRAKE ENGINEERING:-
RR LEFT CA2214
RR RIGHT CA2214R
Part numbers:-
AMK:-
RR LEFT TCA3069
RR RIGHT TCA3070
SHAFTEC:-
RR LEFT BC8896
RR RIGHT BC8896R
BRAKE ENGINEERING:-
RR LEFT CA2214
RR RIGHT CA2214R
Which ones did you get a hold of in the end?
Yeah they did, cheers for the help!
I ended up with the AMK ones. Rhauri helped swap them over and they seem spot on.
Mine needed to be done ASAP, especially on the drivers side. The brake pads were pretty much non existent!!
Thanks guys for your advice , phoned Shaftec today very helpful price is £ 75.00 + VAT each ,will find out tomorrow if they have any in stock, if so going to change them both as its sods law the N/S will seize,
Thanks again Mick.
Thanks again Mick.
thats a hell of a good price. do they sell to normal consumers or only retailers? Maybe interested in a pair if they thats all they are
Gonna check at work tomorrow, we supply BE calipers, will report back on price/availability.
