Rear brake pistons
#21
UK Moderator
Or really cheap here: http://www.amazon.co.uk/dp/B0045KBN7...8954JDYC2ZWDVM
#22
Like lovegroover said you can get by without a special tool, I did manage to wind mine back in,
but if the pistons are seized or tight at all, then the proper tool makes it much easier
I have now bought a universal one from ebay
http://www.ebay.co.u...-/171760343307?
which makes it all so easy
you'd be welcome to borrow it but you're a little far way
#23
perhaps seizures due to over stretched fulcrum angle,<so needing to pull handbrake up to far>and leaving it on,
that"s just relying with self adjustment mechanisms only.
Some handbrakes will not reach desired efficiency on a testing at MOT without nipple removal and adjusted by hand.
#24
Thanks for the replies and knowledge guys. Before there was the talk of not removing the nipple, I ground mine off (ow!! ) at 8.30 this morning before work. I've never fitted rear pads on the S but now the reason you need the cross grooves on the piston at 12 to 6 o'clock and 9 to 3 (i.e. +) makes sense. If I've knackered the self adjustment of the handbrake I'll simply buy a new set of pads (BTW mine are Honda oem) and lesson learnt. I must admit the handbrake is now higher but it is holding the car.
I'll see how it goes but by heck the brakes are great now! Thanks for all the advice, its great to get to know how the car works. As for winding the piston in, I use an open ended spanner that fit nicely around one of the "quarters".
#25
UK Moderator
You can/should adjust the handbrake as part of the pad replacement procedure. There's a nut under the centre console to do it. Instructions in the Service Manual which is widely available via Google.
#26
#27
#28
Originally Posted by Rich007' timestamp='1431607573' post='23612580
interesting topic and useful for me as I am about to change the rear pads and disks (with help).
My mechanic has said he needs a special tool to wind the pistons in so the pads can be fitted. is that right? can this be done without any specialist tools?
I did not have a problem with the S2k but my wife's civic was a pain I had to get a G clamp on them
#29
The 3/8" ratchet will wind in as easily as it'll wind out if the piston/adjuster isn't seized. These pistons must be wound back in so how you got them compressed with a G clamp i'm not sure?!
#30
The proper tool turns and pushes at the same time, which is what you're meant to do. If you just turn it then you're pulling on the stud which is only held in by a circlip at the bottom. If you just push you're going to force it to turn, the reverse of what happens when it comes out, but you're pushing against a thread - like doing up a screw with a hammer.
Everybody should take one apart just to see how it works.
