rear click when braking
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
There are quite a few threads on this subject, but couldn't find what I wanted.
I get a click when I reverse then brake, and then another when I go forward and brake - just once per direction change. This is intermittent and only noticeable when parking at home. I suspect callipers or pads, but as it is at TGM’s next week (it's suspension/bushes/springs/money/painful time) I want to ask them to check this out and will ask he checks the rear wheel nuts are torqued correctly. So, what is the value he should use?
![emot-tip-wink.gif](https://www.s2ki.com/forums/images/smilies/emot-tip-wink.gif)
Found this the other day when looking for the damper top nut torque values. Not sure how reliable it is but it's definitely better than me guessing. I think americans refer to wheel nuts as lug nuts -
https://www.s2ki.com/s2000/topic/742...-part-numbers/
And then convert to english -
http://www.convertunits.com/from/ft+lb/to/N+m/
