Washer jet issue
Old 03-05-2018, 12:09 PM
UK Paul's Avatar
Default Washer jet issue
Drivers side.
Took it out back to the Y tube, short length is fine, spilt the jet from the 90 bend and what turns out is a rudimental non return piece?
Freed the ball bearing as it was jammed solid and can feel it 'breathing through' when I blow on it, with the ball bearing at either end now.
Bearing occasionally jams, is that fine as it still blows...?
anyhow putting it back together I take it the arrow on the non return piece needs to point to the jets...didn't see it until I had it in bits...
Old 03-05-2018, 12:53 PM
alexrobinson202's Avatar
I had this same problem too, and freeing the ball didn’t help matters. Get yourself down Halfords and get a new valve, only costs £2 or so! And yes, arrow pointing direction of fluid flow.
Old 03-05-2018, 01:12 PM
Nottm_S2's Avatar
Me too
Honda even do them cheap. Or use a bit of brake pipe .
Old 03-06-2018, 01:52 AM
RevRanger's Avatar
The little metal O rings in the One Way Values degrade over time. I replaced both, jobs a good un!
Parts PFKL562640 - VALVE, ONE WAY (MITSUBA)
https://www.lingshondaparts.com/hond...0&block_05=hcr
Old 03-06-2018, 03:22 AM
fluffyninja's Avatar
I used a small drill bit by hand to bore it out and chucked the ball away. Made no difference to the performance of the jets for about 5 or 6 years of use
Old 03-06-2018, 03:26 AM
RevRanger's Avatar
... which was the last time the car got washed!!!!
Old 03-06-2018, 12:20 PM
UK Paul's Avatar
Halfords..
Anything in particular to ask for? Or just washer jet non return valve :-)
Old 03-06-2018, 12:34 PM
UK Paul's Avatar
£12.50 each!!!
Old 03-07-2018, 03:23 AM
I'm insulted! The last time I washed it was at least a year or two before that
I was normally far too busy driving it or getting pi$$ed with you reprobates
tbpom1003
12-28-2014 01:01 PM
3d153
09-05-2012 02:38 PM
atlantino224
01-22-2012 06:14 AM
jfw432
06-25-2007 03:23 PM
dhayner
04-20-2005 09:14 AM
Quick Reply: Washer jet issue
