Refurbing calipers
Old Oct 27, 2010 | 11:24 AM
S2k Eire's Avatar
Default Refurbing calipers
When refurbing calipers is there anything else I should order as well as a rebuild kit and piston.
I'm going to refurb all four corners at once.
Is the old piston generally ok to go back in once the pitting has been removed/sanded?
Joe
Old Oct 27, 2010 | 11:31 AM
Itchy Dick's Avatar
I think that once the piston has signs of rust/pitting, it is inevitable it will return.
I remember a while back a member (GaryB iirc) had some stainless steel pistons made to order, maybe worth checking how much they are to make/buy.
Old Oct 27, 2010 | 11:57 AM
Dembo's Avatar
Brake fluid? Or is that insulting your intelligence.
What's the grease you can use on pistons? I need to do all four of mine sometime soon as well. The rears I did 2 years ago, but have become pretty stiff once again, so maybe that suggests not replacing the pistons was a mistake. Or maybe the mistake was not using grease on the bore.
Old Oct 27, 2010 | 12:21 PM
Nick Graves's Avatar
If you get the proper Honda kit, you get a little sachet of lube for the seals/rubbers & one for the calipers, too.
lower's Avatar
The pistons are plated mild steel. Once they rust the plating is knackered.
You can clean them up but the rust will come back.
Old Oct 27, 2010 | 11:57 PM
S2k Eire's Avatar
Just a little bit
Thanks for the help, gettin parts sorted now
Old Oct 28, 2010 | 12:31 AM
Itchy Dick's Avatar
Search is your friend -
https://www.s2ki.com/forums/index.ph...pic=744187&hl=
Rock Auto -
(front and rear piston sizes are the same)
http://www.rockauto.com/catalog/raframecatalog.php
Edit -
https://www.s2ki.com/forums/index.ph...pic=742796&hl=
Old Oct 28, 2010 | 04:46 AM
Ste_Nova's Avatar
i covered the pistons on mine with red rubber grease
hornyhonda
Jun 13, 2017 03:37 PM
marcrx5
R&C Parts For Sale
Mar 14, 2013 07:30 PM
AusS2000
Jul 2, 2006 10:44 PM
monkeymaker
Mar 29, 2003 09:53 AM
