regrease shifter
Old Mar 23, 2015 | 05:22 AM
garyg4761's Avatar
Default regrease shifter
Does anyone have any idea what grease to use when regressing our shifters,will use shin etsu on rubber bits but what's best for the rest?
Old Mar 23, 2015 | 05:24 AM
Moddiction's Avatar
Former Sponsor
Urea grease.
Old Mar 23, 2015 | 06:02 AM
garyg4761's Avatar
Any idea where I could get urea grease,none on flea bay.
Old Mar 23, 2015 | 06:18 AM
chrispayze's Avatar
I ended up getting some from a Honda dealer. Si at Hendy should be able to get some for you. He's a regular in the traders section.
Old Mar 23, 2015 | 07:20 AM
BenRNBP's Avatar
I used Starbrite marine bearing grease in mine and it's still going fine a few years later.
Something like this would do the job I reckon: http://www.ebay.co.uk/itm/100g-Extra...-/171707951743
Last time I checked the Honda stuff was about £24 per pot and I really, really have enough types of grease in my shed
Super High Temperature Urea Grease P/N 08798-9002
Description and/or Usage
Medium-viscosity grease used to lubricate parts with metal-to-metal and metal-to-plastic contact. It’s good for mainshaft splines and clutch pivot points.
Old Mar 23, 2015 | 11:10 AM
tomsimes's Avatar
I used high temp moly grease from eurocarparts - £6 for a pretty big tin of the stuff, and did the clutch slave cylinder rod at the same time.
Old Mar 24, 2015 | 01:50 AM
Irish TuneR's Avatar
I used Silkolene PRO RG2 Racing Grease cause it was there....
Old Mar 24, 2015 | 03:31 AM
Valkyrie's Avatar
I just used some black moly ordered from Opie at the same time as various other fluids. Worked a treat.
Old Mar 24, 2015 | 03:46 AM
richmc's Avatar
I managed to get the Honda stuff from an online supplier in Ireland, try a search, I'm sure it will come up.
Old Mar 24, 2015 | 04:22 AM
Zen1's Avatar
I bought a tub of this off ebay for £5.95
http://www.ebay.co.uk/itm/4005727137...%3AMEBIDX%3AIT
