removing engine
removing engine
hi guys
yesterday i pulled everything off my s2000 engine ready for removal and i have borrowed a engine crane but have come up a bit stuck
i cant find any factory lifting eye's or points to pick it up from,
should the engine have them ?
if not what did you guys use to hoist the engine out?
update
hi guys
i was told you can remove any rwd engine both leaving the gearbox attatched to the car and i just dont understand why it wont come free
update
hi guys
ok so i have some chain and a couple of bolts in place,
engine is on hoist (hoist arm at full extension but stilll a bit short)
gearbox is un-bolted from engine and about a 10mm gap between engine and box and the engine will not move any further,
what other then the gearbox spline in the clutch plate would stop the engine from coming away from the gearbox?
i have tried using a screwdriver or prybar to force it free and it wont move any further.
HELP!!!
HELP!!!
that guide looks way to simple.
biggest one is will the engine come out in one go with the gearbox? it always looked like it needed to be split.
edit: oh. step 5: remove the transmission - that answers my question!
ok so 2 min call to Rob at Garage-R and that man is seriously clued up on these cars, told me instantly what i had left in,
what a LEGEND
i did not realise S2000's have a pull type clutch and not a push clutch, so remove clutch slave cylinder and clutch fork and now it looks like this
Many thanks to Rob at Garage-R he really knows his stuff
what a LEGEND
