Replacement timing chain
1. I cant see that chain stretching.. it's pretty sturdy
Originally Posted by s2000tim,Sep 18 2008, 10:47 AM
Noise went away on its own after doing an oil change.
The glazing of the thread on a part is one, sandblasting this seems to have positive results in creating more friction.
The other is to do with the hydraulic component of the TCT, it seems this might be leaking pressure hence why it can be noisy on the first start of the day so choice of oil might be an issue.
Mobil 1 is coming up as a possible in the problem.
Maybe thinner oil 0-30 for instance might be a factor?
Originally Posted by strar8,Sep 18 2008, 12:53 PM
Would it be head off to just inspect the chain as well? I had the oil changed when i got the TCT changed as well.
IIRC with bike chains you hold them sideways and measure the deflection.
Out of interest-
How many miles on the engine?
What oil/grade are you using?
mines actually started doing the same thing - replaced the tensioner about 2 months ago. a right PITA - although, its no-where near as bad as it was, and generally seems to do it when oil is at -50%...
actually, on a side note, should there be a warning light come on when oil is low and at what point!?!
Checked mine the other day and i was shocked to have used a litre of oil in just two weeks - oil was sitting just on the 'L' and there were no lights!!!!! The light does work when i switch the engine on though...
edit: Car has done 91K. Using Shell Ultra 5-40w
Perhaps worth trying next time, see if it improves TCT noise?
I've just ordered some Amsoil 10-30w for the next oil change.
Opie Oils sent me a 15% off code which ends today -
Enter BB711 into the discount coupon section if anyone is interested
Originally Posted by Nottm_S2,Sep 18 2008, 02:24 AM
2. If it did it's head off to replace it, new head gasket, exhaust gasket etc. you'll be looking at several hundred quid plus the parts
Originally Posted by Guzzie,Sep 18 2008, 01:41 PM
Why would you have to take the head off the engine to change the timing chain? you dont have to do that when changing a timing belt on any other honda engines?
but if you start turning the crank and you're not turning the cam in sync it's bye bye to straight valves so you won't even be able to get the old one off without damage
go have a look here
The only oil light you have is a low oil pressure light and if that comes on its usually too late.
