Replacement timing chain
Old Sep 15, 2008 | 05:08 AM
strar8's Avatar
Default Replacement timing chain
I had a ticking noise about 4 months ago and ended up getting my timing chain tensioner changed, with the valve tappet clearances checked and an oil change at the same time. The bloody noise is back and when i took it to the garage i use (used to work with Honda and has an S2000 himself) he reckons the timing chain has "stretched" and will require replacing which he says is a big job. Anyone else had the same thing and how much am i looking at paying to get it replaced?
Old Sep 16, 2008 | 06:30 AM
strar8's Avatar
No-one?
Old Sep 16, 2008 | 07:00 AM
lower's Avatar
The timing chain can stretch and personally i think that is why some people seem to have gone through loads of timing chain tensioners as the tensioner is working right on the very end of its travel.
Can't help you with the cost though, sorry.
Old Sep 16, 2008 | 11:08 AM
mikdys's Avatar
Check out this thread:
https://www.s2ki.com/forums/index.ph...=320897&st=500
(If it was me I'd try sandblasting the tensioner internals before doing anything else - got to be the cheapest option and you'll soon know if it worked.)
Old Sep 17, 2008 | 07:01 AM
strar8's Avatar
If i was to get it sandblasted where would i take it to get it done?
Old Sep 17, 2008 | 09:08 AM
s2000tim's Avatar
As I have just replaced my engine, I can sell you my old timing chain if you like. Its in v good condition according to my mechanic. let me know if you need it.
Old Sep 18, 2008 | 12:45 AM
strar8's Avatar
Bought warranty with the car and just foned them to see if i could get it done under warranty...apparently the timing chain stretching (deterioration over time) isn't covered and only sudden mechanical breakdown is covered
Old Sep 18, 2008 | 01:47 AM
s2000tim's Avatar
Also, be careful. Exactly the same thing happened to me. Had TCT replaced by Honda. A few months later, noise came back. Was told by Honda that the chain had stretched. Quoted me stupid money to fix it. I didnt. Noise went away on its own after doing an oil change.
Now that my engine is dead, after taking it all apart, the mechanic fixing it now tells me there is absolutely nothing wrong with the timing chain and in fact, it looks almost perfect and its certainly not "stretched" in any way.
I dont trust dealers at all but obviously, thats my opinion.
Old Sep 18, 2008 | 02:24 AM
Nottm_S2's Avatar
1. I cant see that chain stretching.. it's pretty sturdy
2. If it did it's head off to replace it, new head gasket, exhaust gasket etc. you'll be looking at several hundred quid plus the parts
3. The F20C is a ticky engine by default, are you sure you're not being sensitive?
Old Sep 18, 2008 | 02:33 AM
s2000tim's Avatar
If i remember correctly, I was quoted almost
