roof leak
roof leak
my roof is leaking
its leaking from the driver side corner were the window the roof and the windshield meet.
any easy way to fix this? or is it a take it to honda job?
cheers
JM
cheers
JM
Get some Shin Etzu silicone grease from the dealer. Carefully clean and grease all the seals around the hood.
While you are doing this check that the drain in the A pillar seals is not blocked.
also check that the rubber insert near the top of the windscreen inside the seal is in place correctly.
