Rotrex finaly installed
Old May 5, 2008 | 11:43 AM
  #21
Guzzie's Avatar
Originally Posted by HORSEPOWER,May 5 2008, 11:26 AM
Ox' oil temps up to 120-30 C are OK with good synthetic oil. An oil cooler looks in order if you were to track day etc. Paulo wants a cooler (the Portugues guys car) so I will develop a kit. The parts are readily available and reasonable price. I will make up a couple of kits. email me.
Glad you had some fun with the car today, I can't wait to build mine.
Hi Horsepower are you from TTS?
Old May 5, 2008 | 11:57 AM
  #22
Kobe's Avatar
non supercharged S2000's reach that sort of temperature on track..
so as you suggest.. oil cooler would be essential for prolonged high rpm..
Old May 5, 2008 | 11:59 AM
  #23
TTS Performance's Avatar
Former Sponsor
Guzzie. Yes
Old May 5, 2008 | 12:08 PM
  #24
Guzzie's Avatar
yhpm
Old May 6, 2008 | 12:11 AM
  #25
Bibbs's Avatar
I've been looking into this too.
If you could make a kit up I'd be after one.
I'd be after a sandwich plate with two take offs for the cooler, and then two take offs for pressure/temperature.
I was also after a thermostatted one, but can't find one plate that will do the lot.
I was seeing 115 degrees last summer at (high)motorway speeds.
Old May 6, 2008 | 12:47 AM
  #26
joper90's Avatar
is the block just 100% standard? and are you happy with the tune?
Old May 6, 2008 | 03:28 AM
  #27
trinis2001's Avatar
I don't understand those original power ratings. It looks like the original was 150whp and <100 ft-lbs. which I have never seen quoted for an S till now.
Anyone can clear this up for me?
Old May 6, 2008 | 03:55 AM
  #28
Survey S2000's Avatar
the figure quoted is wheel horse power not enginee power output.
Old May 6, 2008 | 04:11 AM
  #29
Bibbs's Avatar
Don't look at the numbers, look at the %age gains. It should give you an idea of what extra you get "over stock".
We had a LONG discussion about this last time (and why it was asked, not to have it again in this thread )
Old May 6, 2008 | 07:57 AM
  #30
wingnutLP's Avatar
old thread which explains the low "before" output is here: https://www.s2ki.com/forums/index.php?showtopic=585177
so oil cooler may be in order...
Bibbs are you fitting an oil pressure guage or would that not have helped you avoid your problem?
