Rust Question
Old Feb 24, 2008 | 11:21 AM
s2000ky's Avatar
Default Rust Question
Hi All,
I think it must have had a panel replaced or similar at some point as underneath the door the join underneath to the outer edge has a line of rust down it. It doesn't look majorly bad but I would like to remove and treat for the future..
I have looked at a load of guides which say to get wire brushes on and get to bare metal then re-paint etc (eek!!)
Is there not a simple way of removing and treating (maybe touching up with a paint stick or similar after) that doesn't involve sanding and respraying? It is literally a mm wide by about 2 inches in length if that.
Have seen a few products like Hammerite and Jenolite but unsure what to do for the best...
Thanks
Old Feb 24, 2008 | 11:42 AM
aldfort's Avatar
The right way to treat rust is to get the paint off, treat the rust, re-prime and repaint. But then you know that right?
If you want to do a holding job get a rust converter like Krust or similar, clean the area and apply with a small brush. Give a second coat when dry. The rust will convert to a phospate. Remove all traces of converter from the paint and then touch up with a paint stick or similar.
However this is not a cure!!!!!!
Trunkz
Mar 5, 2015 12:54 PM
Abernack
Aug 30, 2013 03:54 PM
Red Bull
Sep 9, 2007 09:11 PM
march2000
Apr 26, 2006 01:45 PM
Wisconsin S2k
Jul 1, 2002 09:44 PM
