Rust rust rust
Old Apr 16, 2009 | 11:51 PM
Bassoctopus's Avatar
Default Rust rust rust
I took my S to my local bodyshop today to check the rust on the front wings behind the wheel and the the rear arches.
Apparently to do a proper job on it - both front and rear wings need to be stripped down and repainted. As this is about 3/4s of the car I was expecting a massive cost. I was then pleasantly suprised to hear that my trusted bodyshop (used many times before) will do it for
Old Apr 16, 2009 | 11:58 PM
vadhert's Avatar
Originally Posted by Bassoctopus,Apr 17 2009, 08:51 AM
Those with newer cars, keep on top of the rear arches. get the mud cleaned out from the inside of the arch regularly and get those protectors off every year to clean the arches. Making sure you refit afterwards of course.
Top advice
Old Apr 17, 2009 | 12:00 AM
I thought I'd get away with just getting the inside rear arches stripped, painted and put the protectors back on, but the rust is starting to bubble on the outside of the rear wings too.
Old Apr 17, 2009 | 12:02 AM
J_D's Avatar
J_D
I keep on top of the stone chips on the front wings using Honda touch up paint, which has stoped any rust forming at all.
Old Apr 17, 2009 | 12:59 AM
Ultra_Nexus's Avatar
Once you take those protectors off, DO NOT PUT THEM BACK ON!!!!
Unless they are in PERFECT condition, they trap all the crap and accelerate the rust.
The trick to rust free arches is simply cleaning them and get some waxoyl brushed on.
Totally easy, totally effective
Old Apr 17, 2009 | 01:16 AM
I'm getting some new protectors for mine.
Old Apr 17, 2009 | 01:27 AM
s2konroids's Avatar
[QUOTE=Bassoctopus,Apr 17 2009, 10:16 AM] I'm getting some new protectors for mine.
Old Apr 17, 2009 | 01:39 AM
Old Apr 17, 2009 | 01:51 AM
eho's Avatar
eho
I am thinking of doing this, do you guys use the "clear" version of the waxoyl on the arches under the protected strip?
Old Apr 17, 2009 | 01:59 AM
composite guru's Avatar
I find that removing the rubbers, spraying clear waxoyl directly into the gap in the rubber and refitting them so the waxoyl squidges out to ensure the rubber is completely full and no air gaps.
I do this every year.
