S2000 engine
no no, nitrous wasn't installed... guessing you read my FS?
I just have no idea what happened... there has only been one more case that i found on s2ki where heat and scoring occured on the intake camshaft casings.. it's such a strange fault, I think there was something wrong with the oil system or something... as oil has always been monitored!!
She know's matey, she know's , fortunatly she earns loads ,and she can keep me in the custom to which I am trying to be come acustomed . (does that make sense )?
Also thinking about it I used to work for the poxiest company you could ever imagine (starts with T and ends with sco ) so could well be a blessing .
Originally Posted by Nick Graves,Aug 18 2009, 08:58 PM
I'd rather put in an unopened engine that prat about with a broken one - it is usually a fool's errand.
Don't worry about model years and DBW and shit; you can transplant 'your' manifold etc onto the new engine and it will work.
Later engines will break just as effectively if mistreated.
I think I said that on your orginal thread
There are two ways I can think of to score cams;
1. Drive like a c unt with a cold engine. Or these muppets who tread on the throttle during starting.
2. Drive like Carlos Fandango with overheated or degraded oil on a track day. The car could do with an oil cooler, really.
The first will tend to do lobes, the second tend to do bearings.
In fairness there have been a few F20C that have lunched themselves this way.
IIRC Dembo's plus a few yanks.
I suspect many go undiagnosed as when it goes the end result is pistons eating valves masking the original fault
I'm inclined to agree on the cooler.
The poxy water/oil heat exchanger built in to the oil filter mount is
Nah I personally NEVER floored the car when the engine was cold, never above 3k at all until the water temps were up... And the oil was fresh and was due for a change (same with filter) had roughly 6k miles on it...
Could this problem have occured before me, then if I kept it well with oils etc it could slow down the time of failure?? It was noted that the head had been removed before... so I have no clue as to why the engine would blow... :S
AP1Theory
May 4, 2012 01:20 AM
