S2000 V6 Conversion
Old Mar 10, 2016 | 03:51 AM
  #21
Nick Graves's Avatar
J-series do sound very pleasant.
Old Mar 11, 2016 | 09:40 AM
  #22
CHIPPO's Avatar
Most likely a complete non starter but sitting here just had a mad idea , also I suspect far far to expensive
Honda V6 250bhp 3.5 litre V6 with Max rpm of 5800 .light weight , compact 60 degree
Out board boat engine !!
Old Mar 11, 2016 | 09:57 AM
  #23
J32Vic's Avatar
A short video showing a J32A2 swapped S2K, interesting to mote the block still squeezes in behind the line of the front suspension towers. Gives a good idea of bay clearance too.
https://www.youtube.com/embed/tiMnoaw5az0
Chippo - J32A1, cheap as chips, plentiful and the same basic motor in both automotive and naval applications. 225bhp though.
Old Mar 11, 2016 | 12:53 PM
  #24
surfer_crx's Avatar
After the comments the other day about engine size I did go and measure it and compare to the F20 and although it is hard to get an exact measurement without getting the car on the ramp, I estimate the J30 to be between 25mm and 50mm shorter than the F20 so with the adaptor plate in place it shouldn't sit any further forward than the F20
Can you link me to these cheap outboard engines, I've had a quick look and can't find them?
In other news I made some datum plugs at work today to plug up the crank and fixing holes so I can get a millimetre accurate measurement of the mountings, tomorrow I will be making a perspex adapter using the measurements before ordering my alloy plate and making the real thing. Hoping to be ready for a trial fit next weekend.
Old Mar 11, 2016 | 01:21 PM
  #25
unclefester's Avatar
http://www.v6performance.net/forums/...e-engines.html
Old Mar 11, 2016 | 10:29 PM
  #26
imc27's Avatar
Wouldn't that restrict the rear visibility a bit?
Old Mar 11, 2016 | 11:24 PM
  #27
CHIPPO's Avatar
You would also need to tow a trailer with a large tank for cooling
Old Mar 12, 2016 | 08:10 AM
  #28
That IS a J35 on its end!
Old Mar 12, 2016 | 10:16 AM
  #29
Carl Bourbon's Avatar
Will be keeping an eye on this, good luck with the build, if you need any help info or advice I'll try my best to help.
Like someone said I've done an engine swap to a V8 which is a tad bigger than your V6, you shouldn't have too many issues fitting it in, at least not as much as I did haha!
But yeah, crack on I'd love to see this completed!
Old Mar 12, 2016 | 10:32 PM
  #30
R32 lump and running gear would be a giggle .....
