Scanguage
Old Jan 2, 2009 | 09:20 AM
NineBolts's Avatar
Default Scanguage
Now to go a play with the buttons...
Old Jan 2, 2009 | 09:25 AM
LTB's Avatar
LTB
That looks like a really nice install.
Top work.
Old Jan 2, 2009 | 09:30 AM
MUG3N's Avatar
That does look very neat, you made a very cumbersome looking device look hitech, well done!
More impressive you obviously found Puppy
Old Jan 2, 2009 | 10:00 AM
Bramblecat's Avatar
Looks most impressive and very professional. What does it look like from the back and can the radio stay in as well?
Old Jan 2, 2009 | 10:02 AM
Boab01's Avatar
That's nice would love to see a how to.
Old Jan 2, 2009 | 10:13 AM
vfast1's Avatar
You sure this isnt photoshopped??
Old Jan 2, 2009 | 10:19 AM
NineBolts's Avatar
The back of the radio door has the back of the Scanguage embeded into it. The back of the casing holds all the gubbins in place.
My first attempt to hold the back onto the door tried to mimmick the fixing on the scanguage case front but the glue kept failing on the ABS door. In the end I just ran a bead of hot glue round it. The door closes without hitting the radio.
Old Jan 2, 2009 | 10:45 AM
AquilaEagle's Avatar
Administrator
Nice install - pics of the back of the door?
Old Jan 2, 2009 | 11:25 AM
NineBolts's Avatar
Just been out to play with the buttons and made the background colour Orange to match everything else.
To prove it's not a PhotoShop job (I'd make a better job of it in PhotoShop) here is a picture of the back, glue blobs and all.
I've got some black automotive sealant that I'm going to run round the edge that should hide the glue and blend it into the rest of the back of the door. The other option that I though about and may still try is to cut a larger hole so the Scanguage front casing can sit level with the front of the door. I almost bought a CR door (Carbon Fibre effect) and would have gone for a flush fit of the whole unit if fitting using that door.
Old Jan 2, 2009 | 11:35 AM
s2konroids's Avatar
Nice work, how do you find the scan guage for showing accurate Uk MPG?
