In for a service
My S is going in for a service tomorrow at my local dealership - Steels Hereford.
Being done on a Honda 12 service, so I will see what comes back. Be interesting to see how their customer service is too.
Anyone have any 'trick' questions I should be asking to see if they're decent?
Craig
Craig
A 12 service is hardly rocket science - the best test is to see what they report in terms of brake wear.
- Note any body damage
- Fit car protection kit
- Check operation of all lights
- Check operation of horn
- Check operation of wipers
- Check operation of windscreen washers
- Top up washer fluid
- Drain and refill engine oil
- Replace engine oil filter and sump washer
- Inspect brake pipes and fuel lines
- Inspect exhaust system
- Inspect front brake pads % wear
- Inspect rear brake pads/shoes % wear. Remove brake drums if required
- Inspect brake discs
- Inspect cooling system for leaks
- Inspect auxiliary drive belts
- Check antifreeze content
- Check all fluid levels
- Check battery condition - Midtronics Tester
- Inspect tyres and set pressures
- Report on tyre tread depth (mm)
- Check front and rear suspension
- Check wheel bearings
- Check driveshaft and gaiters
- Check track rod ends and ball joints
- Check and adjust handbrake
- Road test brakes
- Road test steering
- Road test suspension
- Road test engine and transmissions
- Road test heating system
- Road test check for abnormal noises
- Complete safety health check
- Note any additional work required
- Inspect underbody for corrosion
- Road test brakes
Funny responses
I had thought I'd seen somewhere a few questions and queries that newbies should use to test the dealership on their experience, etc. Perhaps I'm wrong.
They have a good reputation within the county, but obviously S2000s are hardly an everyday motor they'd be seeing. I think I'm the only one in Hereford, or at least reguarly in Hereford.
I don't suppose any Hereford(shire) based S2000 owners have used them? Or if not, who do you recommend?
