shut off while driving..now no start
Old Aug 28, 2017 | 12:07 PM
imnotjdm's Avatar
Default shut off while driving..now no start
01 137k miles, all stock based out of lakenheath/mildenhall area
hopefully someone got an idea as to what may be going on. normal driving nothing out the ordinary till I started hearing a rattle for a second kinda like if the heat shield was loose or something (TCT?), suddenly the car jerked/hesitated for a second and kept going fine. .5 mile down the road coming up to a stop the car shut off and had the oil light/battery light come on - still had headlights/radio etc. Tried to turn it back on and it just made a click just like when the battery dies. Tried to get a jump start..nothing, tried a push start..nothing. Checked fuses, connection to the batt, immobilizer is all good, fuel pump primes and no funky smells. Left the car parked overnight and today I took out the battery to get it recharged just in case..still nothing. I don't have a socket big enough to try and spin the crankshaft as of now.
appreciate the help,
pic of said car
Old Aug 28, 2017 | 02:11 PM
RobinA3's Avatar
From what you have said I am wondering if you've got a seized bottom end.
Take the spark plugs out and see if you can turn the crank, if you haven't got a socket then you could put it into gear and see if you can move it by pushing the car (or rocking it backwards and forwards).
Old Aug 28, 2017 | 10:32 PM
Nottm_S2's Avatar
I thought that too..
put her in 6th and see if she'll move with a shove
Old Aug 29, 2017 | 12:40 AM
richmc's Avatar
But there is the possibility of a jammed starter motor, if you are lucky.
Rather than turning it over yourself maybe get it towed to where it can done with the sump off and the shells checked. How was the oil level?
Old Aug 29, 2017 | 02:02 AM
Nick Graves's Avatar
Yup - sounds like a fatal error exception has occurred in a line somewhere between the crank and the camshafts.
Old Aug 29, 2017 | 02:27 AM
imnotjdm's Avatar
oil level is good, ill give it a try today to see if it'll move. any recommendation as to where to tow the car to? just got here two weeks ago.
Thanks
Old Aug 29, 2017 | 03:15 AM
ValveBounce's Avatar
Firstly, exercise caution getting it "towed". Flatbed truck is best to avoid potential damage to the LSD.
Next, I would suggest draining the oil into a clean pan, then run a magnet through it. If it picks up ferrous debris then you have a problem. Consider dropping the sump and see what you find.
I'm not sure about S2000 engineers in your area, TGM in Fleet are experts but a long way away.
Old Aug 29, 2017 | 03:29 AM
imnotjdm's Avatar
tried moving it and it just locks up. I guess time to find a shop.
Old Aug 29, 2017 | 03:49 AM
andylong's Avatar
one option would be TDI in Lakeside, Thurrock - know their way around our cars and quite a bit closer
Old Aug 29, 2017 | 04:21 AM
imnotjdm's Avatar
wouldn't happen to have like a ball park idea of how much a rebuild would be - obviously we don't know the exact problem but maybe an idea?
definitely don't have the time to deal with it nor money since i just moved here. would a part out be worth it?
Thanks.
